Can I chage the tuning?
ok,would i cut the part thats in the box or the wall? Like the tunnel going to the slot port? Where would i cut in that pic. maybe draw me a line //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
:idea:if you want to get really fancy with it, calculate how much port needs to go away, and you could just use a circle saw and cut parallel to the port and then just re-cap the end...your port area would change though!!
ie. cut on plain with the ports longest side and add one new piece of wood..this way you would not be changing the internal volume of the box when you cut away the port.
You can cut the port shorter, but it won't be easy with that brace in the way. Also your internal volume will go up, so you might need to add some bracing or pieces of wood to shrink the box back down.
Reciprocating saw would be your best bet if it'll fit in there...
Fear Of Theive
Fear Of Theive
Pittsburgh,Akron Ohio
Fear Of Theive
