Can I Bridge???
Intrepid90
ok, so i have:
2-12 JVC CS-GS5120
Sony XM-ZR604 Xplod 4 Channel 600 watt Car Amplifier
The Subs are in a profesinal built dual seperated box
im wondering if i should drill a hole through the seperating wall and bridge the speakers and if so can someone give me some instructions on how to bridge thnx for your time guys
Don ps i had posted the urls with specs on these items but it wouldent let me post with urls so you can use the model numbers to get the specs if youd be so kind thnx
110W x 4 Max Power into 4 Ohms
150W x 2 (at 2 Ohms) + 300W x1 (at 4 Ohms) Max Power
60W x 2 RMS into 4 Ohms
65W x 4 RMS into 2 Ohms
High Level Sensing Power On
80Hz High Pass filter with -12dB/Octave Slope
80Hz Low Pass Filter with -18dB/Octave Slope
MOSFET Power Supply
RCA & speaker level inputs
Line level thru-put
CEA-2006 Power Compliant
Output Power:
CEA Rating: 60W x 4
DIN 45500 Rating (@ 14 V, THD 0.5 %)
4 ohm: 4 x 60W
2 ohm: 4 x 65W
Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)
4 ohm: 4 x 60W / 1.0% (14.4V, 20 - 20kHz)
2 ohm: 4 x 65W / 0.1% (14.4V, 20 - 20kHz)
Maximum (@ 14.4 V)
4 ohm: 4 x 110W
2 ohm: 4 x 150W
Input:
Low Pass Filter: 80Hz
LPF Roll Off Rate: -18dB/oct
Subsonic High Pass Filter :: 80Hz
Input sensitivity: 0.3 - 6Volts
Output:
Frequency Response: 5Hz - 50kHz
Tolerance: +0 / -3dB
Total Harmonic Distortion (@1 kHz): 0.005%
CEA SN Ratio: 97dB
Min Load Impedance/Ch: 2 ohm
General:
Current drain (@ Rated Power - 4?): 33 Amps (at 4 ohm)
Weight (approx.)(kg): 3.1
Dimensions (WxHxD in mm) approx: 396x55x256
Speaker specs
Subwoofer CS-GS5120
Cone Size 30 cm (12")
Cone Type
Hybrid Fiber Olefin Diaphragm Yes
Frame Stamped Steel / Polish Silver
Surround High Density Foam
Terminals Gold-Plated Screw
Frequency Response 25 - 2,000Hz
Power Handling Capacity (Max. music power) 800W
Power Handling Capacity (RMS power) 250W
Impedance (ohms) 4
Sound Pressure Level 88dB
Weight
Mass 3,900g (8.6lbs)
Magnet Mass 1,106g (2.5lbs)
Mounting Rear/Box
Mounting Depth 140.6 cm (5-9/16")
12" SubwooferMax. Music Power: 800W250 Watts RMS PowerHigh Density Foam EdgeGold-Plated Screw Terminals39 Oz. Strontium MagnetImpedance: 4 Ohms
Thanks for the specs.
To bridge, follow the instructions on the amp owners manual. Bridge channels 1&2 to the first sub, gives you 300W at 4 ohms. Bridge channels 3&4 to the second sub, gives you another 300W at 4 ohms. You do not want to put a hole in the divider between the subs.
Note that you may need all four RCA inout to be filled on the amp, a y-adapter can let you do this.
thnx for the response , i checked my ownsers manual and it dosent sayanything about bridging, so i buy 2 y splitters once for each end of the rca ables i have right, and if i dont drill a hole how am i ganna connect the wire.................. im loist plz help
Read what he said again. He told you to bridge channels 1 & 2 to one of the subs, and channels 3 & 4 to the other sub. You do not need to wire the subs together, no hole is necessary.
I recind my statement, that amp is 3-channel only. Not an amp for your two subs.
http://pdf.crse.com/manuals/3214760111.pdf
You can see bridging in speaker system 2. For that amp, you must wire the subs in stereo, on rear channels 3&4 only. Channels 1&2 are for your speakers. You'll be grossly under powering the subs. Don't expect much out of them.
Get a different amp, made for subs, class D preferably.
lol. thanks. apparently i need an interpreter!
i've learned that entry level Sony amps are quite cheap and the manuals poorly written. They have tricked me before when I assumed they had basic features common to most amplifiers.
you have a 4 channel amplifier. you can bridge the rear channels to make it a 3-channel amp. i see nothing that says you can bridge both front and rear to make it a 2 channel amp. only two of the channels are designed to power subs due to the internal design limitations and LPF availability. the manual says nothing about the front channels being bridgeable, i don't know if they are.
I recommend you get a different amp to run your subs, preferably a Class D mono amp that is made for subs.
I do not recommend you drill a hole between dividers. have wire from each sub land on a speaker terminal for each side of the box. that way you can externally wire them as you see fit. If you do want to internally parallel the subs and have only one speaker wire terminal, you must make the hole as small as possible to fit the wire then seal the hole. if you use silicone or liquid nails, you cannot leave your subs installed for a few days as the fumes will eat away at the glues used in the sub. bad stuff. if you do internally parallel them, make the parallel connection at the speaker terminal - make sure all connections are solid and no internal shorting is possible - i.e. no bare copper strands are visible at any connection.
Intrepid90
Intrepid90
Pasco wa
keep_hope_alive
