My new amp will take 340 watts RMS and my headunit 88watts (all channels added) RMS.
That's a total of 61 amps being used taking (340*2) + (88*2)= 856. I multiplied by two assuming it's not very effective being an A/B amp. 856/14 (assuming my battery isn't doing full voltage) = 61.14 amps. Granted it would probably only use half of that during normal use, if that.
Considering my stock alt is stated at 95 amps I'm assuming it has about 80% efficiency so that would be 76 amps. Assuming normal functions like lights, AC, etc. take half of that it leaves me with 38 amps in reserve. All my stuff would take about that many amps. It's basically going to be using the entirety of the reserves on my alternator. But that's considering I haven't done the Big 3 yet. Taking that into consideration I would say the alternator/battery become 90% (10% more) effective because of the way better current and ground.
That would leave me with 42-44amps instead of 38 amps in reserve, and my equipment would probably use 30amps on average in normal play, going up to 35-40 while peaking. So I'm still going to be using almost all my reserves of alternator amperage when playing music, but at least it should be able to do it. Would you guys suggest investing in a capacitor since after everything my alternator will only have a couple amps in reserve, and a capacitor would keep the voltage more stable?
Thanks in advance.
Thanks in advance.
