dacheatham
Background info:
2008 Nissan Titan
Stock Alt/Interstate Battery
Alpine 9884
Sae1200D
(2) RE SR 10's
I posted yesterday about issues with my SAE-1200D. It was dropping voltage and losing output. At low volume it sounded good but if I turned it up at all the bass would disappear. The gain was set very low. My dist block showed the voltage with the amp off at 13.7, but as soon as I turned it on the voltage would drop to low 12's. With any output it would drop to the low 11's. I immediately turned it off. The amp was a direct replacement for a nine.1. The nine.1 never had any issues.
This morning I tried a different grounding spot, no change.I removed the dist block and went straight to the amp, no change. The amp now is just making the subs flutter. I double checked the polarities of the subs, all were fine. I tried the subs 1 at a time, no change.
At 1st I thought it was my install, but after changing grounds and running a set of RCA's directly from the radio to the amp and seeing no change I am thinking it might be the amp.
I am hoping my 125.2 will be in today. I will throw it in and see what happens.
2008 Nissan Titan
Alpine 9884
Sae1200D
(2) RE SR 10's
