Can a 4 ohm speaker handle 2 ohms?
That's not how it works lol. Your speakers are 4 ohms meaning their voice coil has a resistance of 4 ohms. You can't magically change the impedance of a speaker without reconing it, but you can change the final impedance by putting 2 speakers in parallel or series. Your amp will see a 4 ohm load from the kappas, but say you got another pair of speakers and wired them in parallel, then the amp would see 2 ohms
If you have two single 4 ohm subs if you wire them together you can get a 2 ohm load. It has nothing to do with your subs "handling" 2 ohms. It is just a matter of how they are wired.
Kappas up front are 2 ohm 100w rms, kappa perfects in the rear are 100w rms @ 4 ohm. My RF amp puts out either 50w x 4 @ 4 ohms or 100w x 4 @ 2 ohms. Will both sets see 100w rms?
Its a RF P400.4, its bridgeable, but Im a newb, hence why I paid 311 for someone to install this, but the rears only getting 50w rms makes me sad in pants //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
LOL $311 just to install 1 amp... Yes u can bridge ur channels but that amp is not 2ohm stable when bridged.
Schweino
Schweino
Omaha, NE
Schweino
