Calling 4th order experts.
LosIsATool
How does this look for a 4th? Room is not a issue. Looking for full SQ not so much output. Output never hurts though. I don't want to have to build 4 boxes to get it right. Need 20-63hz
Mine is SC so it has more motor force. More than enough power on tap. Need as flat as possible. Going in a trunk. Seats stay up, no pass through, pretty closed in but it gets plenty into the cabin ported.
http://www.ddaudio.com/products/mobile-audio/woofers/sw2508
well build the sealed portion, play a sweep and see which tone is the loudest between 45-52hz
Tune ported to that resonance to have the flatness you desire
1:1 ratio would be the most "sq" or musical. Is it for your little 8?
btw you linked re audio's amps
well build the sealed portion, play a sweep and see which tone is the loudest between 45-52hzTune ported to that resonance to have the flatness you desire
My bad. Yes it's my little guy.
i take it you get the most out of the sub and the loudest if you tune to the cars resonance right ?
i need to figure out my trucks resonance.
ok.is there another way of testing?
sorry noloud....
also is it possible to get 20 to 63 tune ?
and that 8 is a beast....
Your good. Just some ideas I'm tossing around. I want to change something but I don't have anything to change.
Thinking a plexi 4th would be some more show, judges like show.
^^^^ tline would be nasty
sorry noloud....
there's not another way I know of testing other than starting with the sealed shell. Im sure there is a way. I just don't know of it.
yes you want the sealed and ported to be **** near as close to 1:1 as possible for sq and musicality purposes.
I had my XFL 12 in 1.1 sealed and 2.4 ported. 1.1 sealed brought my sealed resonance just to around 46hz and I believe the tuning of my ported was 45.7. Was loud on just 800 rms. Efficient as hell. Just wasn't as musical as could be. Played from 26-57ish. Fell off hard above and below that
ok you say use a sealed box to check. well what is the sub is not recommended for sealed. would that make any difference ?
for the past year i have been wanting to do this.
and by adding deadener that will chance the res. right ?
and noloud, i dont blame you. im doing the same thing.
trying to change things up as im never satisfied .
T line goes off cone area right? I'm not sure what it is. I guess I could just go in between a 8 and 10
cone area and fs
---------- Post added at 04:18 PM ---------- Previous post was at 04:17 PM ----------
ok you say use a sealed box to check. well what is the sub is not recommended for sealed. would that make any difference ?for the past year i have been wanting to do this.
if it's not recommended for sealed, I recommend 6th order if space permitting. If not, regular ported will trump a 4th
adding deadener will change resonance slightly. Nothing that will be a total deal breaker
cone area and fs
Listed Fs is pre break in. I think I'm going to just leave it alone. It's going to be a pita
cone area and fs
thanks also, was helpful.
LosIsATool
LosIsATool
Pensacola, Florida
Dmac1991
