I wanted to put 2 15" tubes under each seat and 2 15" tubes under each side of the dash and do a underbody kit. so whatever suggestions you can give me is appreciated.You weren't very specific on what you're wanting to use. Are you wanting to use LED tubes for your wheel wells/under seat/door pockets, or single LEDs, like up in your vents or whatever. the latter is a little more complicated.
If you're going with the tubes, look at the oznium stuff someone already posted here or I can set you up with some StreetGlow. It's really simple installation, just + and -. Put a switch on one side so you can turn them on and off. Everything's wired in parallel, so you take all your + wires and solder them together, then take all your - wires and solder them together.
If you can't do this, you can't do car audio //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The cathode kit on oznium would work for under the dash and seats. http://www.oznium.com/cathode-kitI wanted to put 2 15" tubes under each seat and 2 15" tubes under each side of the dash and do a underbody kit. so whatever suggestions you can give me is appreciated.
where do you see that it says 8 dollars for two? its showing me 10.00 for 1 12"The cathode kit on oznium would work for under the dash and seats. http://www.oznium.com/cathode-kitIt's $8 for 2 tubes and the transformer to power them. Thats what I have in my car, cheap and effective.
I would get streetglow for the underbody.
