Calculate Cabin Gain?
bikinpunk
G-g-g-g-g-unity!
I had read in a couple other threads that you can use the
1. longest distance
2. multiply by two
3. divide by 1/4 speed of sound
4. = resonant frequency
However, on step one I'm not sure if I take the longest distance of the trunk or the cabin. I've posted in DIYma 3 times, but haven't gotten any replies yet.
When I use the trunk I get
Cabin Frequency
Longest Length (in) 45
Length * 2 90
Speed of sound (in/s) 13397.244
1/4 of SoS 3349.311
Resonant Frequency 37.21456667
If I were to use Cabin the number would be MUCH lower. Which doesn't seem right since everything I've read says Civics have resonance at 30-50hz. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Take the distance from the end of the trunk to the windshield.
This will not really give the resonant frequency but more so the point at which cabin gain will to have an effect. It's not a BS equation and it worked on two of my vehicles. It won't tell you where to tune your enclosure to max output but it will give you an idea where cabin gain begins.
Well there are two things at play. One is the driver interaction with the air volume in the vehicle, basically it's another chamber of the enclosure. The second that the equation is looking at is building a standing wave in the car using quarter wave theory. You have to consider both and figure which will give you the biggest boost in output. Usually its the first one because you can't nearly rely on the second.
bikinpunk
G-g-g-g-g-unity!
bikinpunk
Alabama
helotaxi
