Cadence Vegas 4 channel amplifier.
I've had it for a couple years in my truck, it works great. Has some scratches, perfectly functional.
Just removed it from my truck because I am probably selling my truck, so I have verified functionality o the amp. I will not be able to accommodate buyers with no feedback score, sorry, maybe at a later time.
The 4channel Class A/B Vegas amplifier is a sure winner you can bet on. The Vegas is only 2inches in length larger than its little brother, the Chicago. But still boasts more power, up to 135watts (RMS) of clean power to all 4 channels. It carries all the same features that make the United Series desirable, including IC-Controlled protection circuitry, studio grade transistors, Mosfet power supply, fully adjustable crossovers, subsonic filter and more. Get the added power you need, without having to compromise for space you can use. Get the Vegas today.
Class AB 4-Channel Amplifier
Specifications
4 Ohm RMS Power: 135 Watts x 4
2 Ohm RMS Power: 225 Watts x 4
4 Ohm Bridged RMS Power: 450 Watts x 2
PEAK Power: 1800 Watts
Minimum THD:
Frequency Response: 10Hz - 40 kHz
S/N Ratio: > 100dB
Damping Factor: > 220 @ 100Hz
Channel Separation: > 65dB
Input Voltage: 200mV - 8V
Fuse Rating: 30 amps x 3
Dimensions (L x W x H): 24" x 7.25" x 2.25"
Features
• High Speed MOSFET Power Supply
• Studio-Grade Bipolar Output Stage Transistors
• Fully Adjustable 12dB / Octave Crossovers
• Low Pass: 40Hz – 150Hz
• High Pass: 50Hz – 500Hz
• 18dB Bass EQ Boost Control
• 3-Channel Mixed Mono Capable
• Mute and Delay Soft Start System
• Full IC-Controlled Protection Circuitry
• Fully Adjustable Subsonic Filter
• Dashboard Bass Remote Control Included
• 8 Volt Pre-Amp Circuitry
• RCA Pre-Amp Line Output
• Input Mode Selector Switch
$325.00 Shipped
Shipping on me. I have the original box. I will put it into another box, and then into another box if I feel it needs it. I don't play around with shipping, lol
Specifications
Minimum THD:
S/N Ratio: > 100dB
Features
$325.00 Shipped
