cadence TXA750D help
YourNameHere
CarAudio.com VIP
ok so im trying to adjust my friends new amp and well cant figure out what some setting are or what they are for... first off there is a phase shift switch that you change to 0 or 180 ....... and second there is subsonic filter dial 10 - 40 hz what should this be set at ? so if anyone is familar with this amp please help a guy out
and i case you need more info on what we are running here some info
sub wiring------ dual 2ohm wired to 1ohm
vehicle--- 2003 chevy trailblazer
box ------> custom fit for vehicle with .75 cuft
sub------> http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3878
amp---------> http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6101
deck------> http://www.sonicelectronix.com/item_7463_Eclipse+CD4000.html
and also if anyone is familiar with deck eclipse cd4000 i need some help also..... my friend said that he once got into a bunch of different frequency tweaking/setting options (not the crossover options) but he cant remember how to get back into it anyone? or what should all the setting roughly be set at, i know its hard to say unless you are actually sitting in the vehicle but just maybe give me a starting piont. thanx
ok so im trying to adjust my friends new amp and well cant figure out what some setting are or what they are for... first off there is a phase shift switch that you change to 0 or 180 ....... and second there is subsonic filter dial 10 - 40 hz what should this be set at ? so if anyone is familar with this amp please help a guy outand i case you need more info on what we are running here some info
RTFO:
Read tha fukin manual
i fukin did! nothin in there about the phase crap and the subsonic filter thats why im on here askin
I owned many cadence amps through out some time
yes it does explain it. :p
subsonic is your cutoff Freq. Pretty much is what the amp cuts off to avoid your moofer from bottoming out, which can be a bish in a ported enclosure. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Subsonic:
Frequencies below 20Hz are usually not able to be reproduced, and with the exception of synthesisers and pipe organs, are not a wanted part of the audio spectrum. This is especially troublesome with phono systems, since many of the vinyl discs you treasure (or wish to transcribe to CD) will be warped to some degree. Any warp in a vinyl disc will cause large outputs in the subsonic region, typically well below 20Hz.
For example, a 33 1/3 RPM album with a single warped section will create a signal in the pickup at 0.55 Hz (33.3 RPM / 60 = 0.555 Hz). This is a signal that will cause significant cone movement, but is undesirable in the extreme. Not only will vented subs be completely unable to handle such a signal linearly, but sealed subs will also be stressed. Large amounts of available power will be wasted trying to reproduce a signal that was never intended to be there in the first place.
To be effective, a subsonic filter has to be very steep - this allows all wanted frequencies to get through, and rejects those that will only cause problems.
At least one circuit that the author knows of uses a method of summing the channels below 140Hz, and although this is effective in removing the low frequency rumble (or sub-rumble in this case) component, it causes frequency response aberrations that (IMO) are not acceptable. The subsonic frequencies generated by record warp are by nature out of phase. The mono component of a vinyl disc is lateral, whereas warp signals are vertical. Stereo signals are at 45° The summing method was examined in great detail before deciding that it should not be used if the overall frequency response of the disc is to be preserved.
ok nevermind asked a friend and thats what i thought from the beginning simply reverses the sub, but now does anybody know about any fine tweaking on the eclipse HU
Here:
The phase switch allows you to switch from in phase to 180* out of phase. This feature is not to taken as written in stone. In some rooms, or locations of a room, the output will sound louder/better either in phase or out of phase. So there is no correct setting. It all depends where the sub is located and the acoustics or shape of the room.
Phase is term that describes multiple characteriscs and behavior of a speaker system.
Phase alignment: The vertical alignment of the voice coils of all the speakers in a speaker cabinet, so that all signals reach the sweet spot at the same time.
Crossover phasing: If one or more crossover slopes are of a different slope, then the speakers would not fire at the same time, causing delays in response.
Reverse polarity: You may reverse the polarity of a speaker to make the speaker fire inwards instead of outwards to improve alignment with the other speakers in the system. This is very common in tweeters circuitry. As for woofers, if the polarity is reversed, there is usually a cancellation of bass, to a degree.
Jeez, it took me 2 seconds to find, so don't tell me you searched
you'd have to retarded to miss the 18340 matches found for your question on askjeeves.com or google
YourNameHere
CarAudio.com VIP
YourNameHere
GAM3OVR
