Cadence S2W10-D2
devast8r3436
These subs are monsters. I bought two to run off my Cadence C65 getting 600 watts each. First off when I took them out of their boxes they were heavy. They are built very well and should last many years. I could barely move the cone area when testing how tight they were and I'm 6'5 and 280 pounds so I am a big boy lol. So they may take longer to break in for some people then others. After I installed them I figured I would try a album I have listened to over and over so I chose G'n'Rs Appetite for Destruction. Not to much bass but I was familiar with the sounds. And I will say I was in awe. I felt the kick drum really come alive. The sound was not over powering my Polk MM components in anyway but complimented them very well. I then went to Jackyl's Best in Show and holy cow they really boomed to life. I must say they had it all over my Treo RSX 12.22 they replaced. I will only use Cadence for my amp, sub, and possibly speaker needs from now on. I will be trying their components next but they have a tall order to fill living up to my Polk MM's. But these are by far the best subs I have heard and they aren't even the top of the line so if you need great subs at a amazing price these are them.
10” Dual 2 Ohm Voice Coil Subwoofer
Specifications:
• RMS Power: 600 Watts
• PEAK Power: 1200 Watts
• Frequency Response: 25Hz – 500Hz
• SPL @ 1w/1m: 91dB
• System Impedance: 2 Ohm DVC
• Mounting Depth: 6.02” (153mm)
Features:
• High Excursion Double Laminated Foam Surround for High Speed Bass Response
• Expanded and Rolled Steel Basket
• Magnet Motor with Heat Pump Cooling Technology
• Magnet Motor Vent
• Quad Layer Linear Progressive Conex Spiders
• Integrated High-Current Tinsel Leads
• Black Aluminum 4-Layer Voice Coil Former
• Ultra Saturated, High “BL” Magnetic Motor Gap
• Extended Pole Technology
• Kevlar Reinforced Ultra-Stiff Paper Composite Cone
• Woven Fiberglass Dustcap
• Molded Rubber Trim Gasket
• Stylized Magnet Protection Rubber Boot
devast8r3436
devast8r3436
Heber Springs, AR
devast8r3436
