cadence ia9 2k at 1 ohm 12v's
mclerico83
tampa
cadence ia9
used 8/10 cosmetic
10/10 mechanical
comes in original box
Specifications:
• 4 Ohm RMS Power: 600W x 1
• 2 Ohm RMS Power: 1000W x 1
• 1 Ohm RMS Power: 2000 Watts
• Twin Amp Bridged Power: 4000W
• Minimum THD:
• Frequency Response: 10Hz – 500Hz
• S/N Ratio: >100dB
• Damping Factor: >230 @ 100Hz
• Dimensions: 16” x 9.25” x 2.5”
Features:
• High Speed MOSFET Power Supply
• BiPolar Japanese Sanken Output Devices
• Copper Rail PCB Architecture
• Input Voltage: 200mV - 9V
• 12 - 24dB Crossover Circuitry
• RCA Preamp Output
• Bass Focus Control
• Adjustable Subsonic Filter
• Adjustable Phase Control
• Soft Start Mute & Delay
• Power & Diagnostic LED Indicators
• Computer Optimized heatsink Design
• iA2, 4 Ohm Bridgeable, Tri-Mode Capable
• Class D Models: 2 Ohm and 1 Ohm Stable
• Class D Twim Amp Bridgeable @ 2 Ohm
• Master / Slave Configuration
300 shipped
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Get your Coupon RIGHT NOW!!!🥳🥳🥳 Let’s celebrate the upgrade of Cadence Sound Website! Take this chance to get the 10% OFF coupon which has no...
It also lowers the amps efficiency and raises the current draw.
474
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
310
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
mclerico83
mclerico83
tampa
mclerico83
    May 18, 2024
    May 18, 2024
