Sold Cadence iA-2 2 channel high end amp
gentlejax
This was from a year or so ago when they made a special line of hand built studio grade amps. they came with 5yr warranties so they must have been made well..looks like a bad *** amp. its jut too big to fit where I need it to without risking damage to it at some point. I must let it go. Its really nice.
Works 100% . it is missing the rca cap cover thing on one of the Outputs which is no big deal unless you are one that actually uses the amp to pass the signal to a 2nd amp.
the caps are easily pulled off. it happens when a rca is too tight. all that would need to be done is pop another one on. they are not soldered...this one isnt anyhow. its just a shield to ground the plug.
it has a couple of scratches but the clear plexi is perfect and looks great. that is how it should be displayed imo.
$150 shipped
Specs
* Input Voltage: 200mV - 9 Volts.
* 12-24dB Crossover Circuitry.
* RCA Preamp Output.
* Bass Focus Control.
* Adjustable Subsonic Filters.
* Adjustable Phase Control.
* Soft Start Mute & Delay.
* Power & Diagnostic LED Indicators.
* Computer Optimized Heatsink Design.
* 2 Channel Models: 4 ohm Bridgeable, Tri-mode Capable.
* Class D Models: 2-ohm and 1-ohm Stable.
* Class D twin amp bridgeable/double output power in to next highest impedance.
* Master/Slave configurable.
* Dashboard bass remote control included with all models.
* Lifetime Warranty
Specifications:
* Rated Power @ 4 ohms RMS: 150 Watts x 2
* Rated Power @ 2 ohms RMS: 300 Watts x 2
* Bridged Power @ 4 ohms RMS: 600 Watts x 1
* Minimum THD at Rated Power:
* Frequency Response: 10Hz - 40KHz
* S/N Ratio: >100 db
* Damping Factor: >1400 @ 100Hz
* Channel Separation: >65dB
Dimensions: 9.25" x 2.5" x 19"
pics
stuff pictures by gentlejax - Photobucket
I just hooked it up to my sub and it is strong. I can def tell the difference in it and the last amp that was on it...and the ones before. I havnt tuned it since I am needing something smaller. its currently sitting on the floor on my back seat and my son is going to step on it back there. but since its all I have to put in the car for sub duty I had to for the meantime.
I need a smaller amp....so I would def trade this for one..
performance wise its really good on my single 12
any interest in an Orion HCCA 10d? (TC based sub, 4 spoke red basket, dual 2 ohm, 600rms rated, heavy, beefy,stout 10" sub)
thansk but if I got another sub I still wouldnt have a amp to run it. I need a smaller amp to fit under my seat...so it doesnt help to trade for sub..thanks though
gentlejax
gentlejax
Bossier City, La.
gentlejax
