C++ Help
shit, i took C++ last year in highschoolmade a program for determining port sizes
all that shit
dice rolling programs for D&D
all that fun shit
and some semi-useful shit
some text based games too
too bad all of it got erased when the school's network got butt****ed over the summer
C++ was fun but its pretty much a dead coding language
alot of highschools dont even teach it anymore
learn java
Dead.
LMAO, you don't know WTF you are talking about tard.
nG
Code:
/*********************************Chad Hicks***********************************/
/***************************     Real to Unsigned  ****************************/
/**************************Written Using Dev-C++ Ver4**************************/
/************************* Written on October 28th 2007************************/
/**************************For Math 240 Alan Smothers**************************/
/*****************************At Concord University****************************/
#include <iostream>
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
#include <math.h>
#include <fstream>
#include <string>
#include <iomanip>
using namespace std;
 // Function Prototypes
 void printbinary(int length, unsigned int* passed, unsigned int value);
 void printhex (int length, unsigned int* passed,unsigned int value);
 int addary (int ary[],int counter,int sum);
 bool testp (string testof, int length,int beg);
 int main()
 string pal;
 int ary1[10];
 for (int countit =0; countit<10; countit++)
     ary1[countit] = countit;
 bool returned;
 float* x;
 unsigned int* y;
 unsigned int value2 = 1; //Initializes the comparision variable to 1 followed by 31 zeros
 cout<<"Input Float Value:     ";
 cin>>*x;  //Input of Floating Value into the address that x points to
 cout<<endl;
 /*  This line of code does 99% of the work for this assignment.  It takes   */
 /*  the float pointer x and reinterprets into integer through the y pointer */
 y = reinterpret_cast<unsigned int*>(x);
 cout<<"Decimal:     "<<*y<<endl<<endl; //Output the translated float variable as a integer decimal
 cout<<"Binary:      ";
 printbinary(0, y, value2); //printbinary call, this function prints the binary representation of the floating point, how it literally looks in memory
 cout<<endl<<endl;
 cout<<"Hex:         ";
 printhex(0,y,0x80000000); //print hexcall, this function prints the hex represntation of the float variable, how it physically looks in memory
 cout<<endl<<endl;
 int sumit = addary(ary1,10,0);
 cout<<"Array Sum:     "<<sumit<<endl<<endl;
 cout<<"Input String to be tested for palindrome"<<endl;
 cin.getline(pal);
 int l = pal.length();
 l--;
 returned  =  testp(pal,l,0);
 system("PAUSE");
 return(0);
 /*     This function recieves length, which is the length of the size of    */
 /*     your float memory location.  It also receives a pointer to a         */
 /*     unsigned integer holding the binary representation of the float.     */
 /*     This function takes the binary representation, does a comparision    */
 /*     then outputs the number in binary                                    */
 void printbinary (int length, unsigned int* passed, unsigned int value)
      bool test = 0;
          if (length<=31)
             printbinary (length+1,passed, value <<1);
             test = value & *passed;  // this & comparison compares the comparision variable to the binary representation in the unsigned int
             cout<<test;
//              value = value >> 1; //this shifting moves the comparision 1 down 1 to compare the next bit position
          else
             return;
             //printbinary (length++, passed, value);
//       cout<<endl<<endl;
 /*     This function takes the binary representation, breaks it up into 4   */
 /*     then translates that into hex and prints it                          */
 void printhex(int length, unsigned int* passed, unsigned int value)
      int a = 8;//a is used in the mathmatical compilation of the hex variable, since 1000 in binary =8
      bool test = 0; // this is used to check if a bit is 1 or 0
      int countit = 0; //countit is used in the compilation of the hex variable
      if (length < 8)
//       for (int loop = 0; loop < 8; loop++)//outer loop is for the different hex values
          for (int loop2 = 1; loop2 < 5; loop2++)//inner loop is to compute a single hex variable
              test = value & *passed; //bit comparision
//               cout<<value<<"   "<<*passed<<"    "<<test<<endl;
              if (test == true)
                   countit = countit + a;// if a bit is 1 then a is added to countit
              a=a>>1; // a is shifted down from 8 to 4 to 2 to 1 in this loop. This allows for hex to be computed correctly
              value = value >> 1; // shifting of the comparision variable
          switch ( countit )  // This switch is to output the Hex for each variable
             case 10: cout<<'A';
                      break;
             case 11: cout<<'B';
                      break;
             case 12: cout<<'C';
                      break;
             case 13: cout<<'D';
                      break;
             case 14: cout<<'E';
                      break;
             case 15: cout<<'F';
                      break;
             default: cout<<countit;
                      break;
          countit = 0; //countit is reset to zero for the next hex variable
          a = 8;  //countit is reset to 8 for the next hex variable
          printhex(length+1, passed, value);
   sum= sum+ary[counter-1];
   if (counter == 2 )
      return sum;
   else
      return addary(ary,counter-1,sum);
bool testp (string testof, int length, int beg)
    cout<<beg<<"     "<<length<<endl;
    if (beg>=length)
       cout<<testof<<" is a palindrome!"<<endl;
       return 1;
    else
        if (testof[beg]!=testof[length])
           cout<<testof<<" is NOT a palindrome!"<<endl;
           return 0;
        else
            testp(testof,length-1,beg+1);
heres the entire program if your wanting to see it noah //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just because java is prettier dont mean its better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
c++ is the driving force for pretty much everything
i also know pascal, now thats a dead language
all that shit
all that fun shit
learn java
My *** c++ is dead... every university is going to teach you either Jave or C++ as your core language. Don' talk till you get to college noob or get into the industry.
lilmaniac2
Ask Me about SI Mag V4!
lilmaniac2
Somewhere, Else
ngsm13
