BX1000D/4v Alpine users...
flatlander4510
I'm running a Magnum D2 (not claw basket if it matters) in a 2 cu. ft. box tuned to 30hz. My Hifonics bx1000d is wired for 1 ohm. My head unit is an Alpine 9835. I won't have access to a volt meter or DMM for a while, so where do you guys have your gains [properly] set to? I only have it about a quarter of the way up from the 9v marking.
Thanks,
-Harrison
Well, since the marks on the hifonics go from 9v to .2(or something like that), then a safe bet would be at about the half-way mark. think of that knob as going from 0-9, so half-way would be 4.5 volts.
4.5 volts is under your headunit rating, so you won't clip the amp.
That's where i set my bx1500d at and i had no problems.
I have to have my gain up very high on this setup as well. The HU tops at 35 and I have it where my mid and highs peak around 27 or 28 and I have to have the gain all the way up for the Hifonics amp and my sub to peak around 27 or 28. The JL 500/1 is what I had before and I had the gain up less than half way. The Hifonics is running @ 2 ohm right now and never gets hot with the gain all the way up....oh well.
definitely should NOT have the gains all the way up, unless your headunit has a .2 volt preout.
flatlander4510
flatlander4510
Mays Landing, New Jersey
tommyk90
