buzzing from speakers/amp
rco8786
Studmuffin
642
Atlanta
ok im running the small amp in my sig for the coax's. and the problem is there is a constant buzzing from each speaker. it is completely unrelated to alt/ignition as it is the same volume at all times. i thought it was ground so i redid that to no avail, then i thought i needed some rca mute plugs, but the other rca jacks are for rca out(to run rca's into another amp).. would this still be a muting problem? it sounds cheap but i don't wanna destroy a 5 dollar pair of rcas just to test something.
Unplug the RCA's from your amp. A muting plug is better than an open, but at least you should be able to tell if the noise is comming through the RCA's or if it's the amp itself. If the noise goes away then hook up another source, like a portable CD player. If there's no noise, then the amp's OK and you need to track down whazzup.
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
205
rco8786
Studmuffin
rco8786
Atlanta
soundgy45
    May 18, 2024
    May 16, 2024
