Busted Amp - need help??
Does it turn on and just has no output? Did you check the fuses (probably so, but recheck them very closely.) Crack the amp open and look for any slight marks on the board itself, if anything looks unusual then replace it. What amp is this? If its a good amp I wouldnt just go out and replace it, there are places that fix amps you know...
If you have power at the amp, a good ground, and voltage at the remote turn on with no output, your amp is smoked. I agree with the other reply, that there are places to get amps fixed, but I wouldn't bother- new amps are pretty inexpensive anymore so unless it's something really good.... time for an upgrade baby!
Hook Me Up
It's Bad Boy Baby
Hook Me Up
Indiana
bikejunkie223
michigan born
    May 14, 2026
michigan born
    May 14, 2026
