burp box daily life
gumby688
Ok am building a spl box for TNESPL finals but I want to still be able to live with it for a couple months until I get my materials and plans together for my 6th order wall here is what I have so far
Going in a 2000 ford explorer vehicle peaks at 45-46. Looking for advice or suggestion for any changes I might need to make.
Internal measurements
22.5 H
32 W
30 D
12.5 cu.ft. before displacement
subs firing up port on rear left corner facing drivers side
22.5 Hx8 Wx12 L 180 square inches of port area
11.25 cu.ft. -.32 for subs 10.93 cu.ft.
theaded rod for bracing corners 45'd final volume is 10.51 cu.ft
Tuned at 43hz
Z v.3 18 dual 2
Fs: 31.9Hz
Re: 4.0ohm
Qms: 5.0
Qes: 0.6
Qts: 0.5
Cms: 45.8
Mms: 541.4g
BL: 25.6N/A
Vas: 96.5L
Sens: 88.5 1W/1m
Le: 3.5mH
There ya go ugly but shows layout
Robert is ported to the drivers side isnt he the box is on passengers side I thought. Here are a couple pics of the box I started today 10.6 cubes tuned at 45hz I even 45'd the corners.
brace that as best as possible. double up that port wall or throw a 1" dowel between the the port and side. good luck at finals- this friggin arm of mine screwed my whole season up.
gumby688
gumby688
Fryeburg,ME
bgowdy
