Built new box, what port config.
skylineTT
bass=sekz
Built my truck box today. 1.5 cubes after sub displacement.. if i do a 4" ABS port, how long will it have to be to get 29hz tuning mounting it inside the box?
i figure at 25", it will consume .15ft^3 of space making the box volume 1.35 internally, making the tuning close to 29. I am unsure if i did this right, and also if my sub will be okay in only 1.35 cubes. :p can anybody clarify this for me? thanks
also, the top depth is 4" and i wanted to upfire the port but it doesnt look possible so i thought about firing it to the passenger side, but it will be about 1.5-2 inches away from the wall. should i just go ahead and side fire it anyway? thanks
Right, but is that with the port inside still? I always thought port volume took away from box volume. Either way though, would side firing that close to a wall even be effective?
If its close to the wall it will basically be like the port being a little longer outside the box. How to figure that distance out I dont know. Will probably be tuned just a little lower when in place, if any.
with the port too close to a wall the port acts like it is a smaller size. which in theory will lower the tuning but could result in "port noise" because the air is hitting a choke point.
skylineTT
bass=sekz
skylineTT
Houston/Dallas
skylineTT
