Completed 2 custom built 15” subs D1.4 34mm xmax
djdilliodon!
Price
$550
Condition (1 worst - 10 best)
9
Massapequa NY
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for added cooling along frame to motor spacers. 3” dual 8 layer 1.4 ohm coils made by precision econo wind using aramid sheet wrapped collars, aluminum flat wire, and black high temp coating. Cones are pulp Kevlar mix with glassed cone backs done by hand. 9” carbon fiber dust caps. Direct 8 ga leads, 4 layer nomex spiders, triple joint rings, and fully built by hand. They have 34 mm of xmax mathematically (not peak to peak). These will handle 1500+ watts rms and will require a box that is 3.75-4.25 cubic feet per sub ported. Not recommended for sealed applications. 2 of these is 3.75 cubic feet each ported in a Honda civic on seeing 3k rms have done 153+ db at 40 hz. These are also very musical to boot! Lead sewing is coming loose which is common for a sub with a ton of xmax, won’t effect performance at all. $550 shipped or obo! Sold the car so these have to go!
Was Photo Included
  1. Yes
Was Note Included
  1. Yes
djdilliodon!
djdilliodon!
NY
djdilliodon!
