building new box.. no table saw...
I have no table saw, what are some other options of getting my peices cut out? My last box I used a circular saw and I didn't like the way it turned out. Would Home Depot or Lowes cut my pieces for me by chance?
what was wrong with it? if you have a good solid setup to cut on and a good straight line, preferably a chalk line, and some practice with a circular saw, then if you should be able to make a good cut. my new circular saw has a laser on it. makes following straight lines so much easier.
X2 on the circular saw. They are cheap and easy to use. In my experience Home Depot is not very accurate at cutting wood. They are at least 1/4-1/2" off all the time. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
yea. just go buy a piece of aluminum in an L shape, and some nice clamps
clamp the aluminum to the left\right (depending on what side of the line you need to cut, line is drawn with a Tsquare) of your line so that the blade lines up with your cutting line.
heres a FULL walkthrough
http://www.taunton.com/finehomebuilding/pages/h00051.asp
**** u all and ur saws lol...I had to use a battery powered saw //content.invisioncic.com/y282845/emoticons/bawling.gif.6287aa5d1d447c8af063fc9466e822ef.gif there are two buttons..u hav to hold this lil *** one then pull themain one then the saw will work but if u slip on the lil button it shuts off...so gets rather annoying...
good thing Im gonna cover it cuz it aint pretty //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
IshbOO
IshbOO
St.Louis, MO
negativezeroz
BP1Fanatic
BP1Fanatic
