Build a tri-box- any advice?-->
d audio 450
Registered User
I wanna put together a sealed box to hold 3 10" MTX 6000's
i want to make each sub independently sealed as well...
does anyone have any suggestions as to how i should build it, what out of, volume ect
i somehow plan to incorporate plexiglass as well for lighting...
any advice, info, or comments would be greatly appreciated
thanks a ton
-Pat
just build each chamber within the subs specs....you need wood glue, drywall screws, silicon, and 3/4" mdf (you should be able to only use 1 sheet, but you might need 2....its cheap as hell anyways like 15-20$/sheet). a screwgun /drill with phillips bit, circular hand saw or tale saw/radial arm.....and you got a setup to build ia great enclosure.
sweet- thanks a ton
anyone have any recommendations for what to use for dampening? i know there are alot of products specificlly manufactured for audio applications...but are there any that are notice-ably better or different?
thanks alot
-pat
I would not use wood glue. Wood glue is great for hard wood wich has pores and grain to bond each piece. I would use liquid nails, Or cheaper route is using sub floor adhesive. (same as liquid nails.) The liqiuid nails when dry makes a nice bond between the pieces. Subfloor adhesive is by nature ment to expand and contract and still keep hold. The intense pressure in your enclosure will hammer that wood glue hard. A large tube of sub floor adhesive is cheap enough, 2.38 at lowes for a 16" tube. Hope I could help.
16
945
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
881
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
953
d audio 450
Registered User
d audio 450
Pa Philly area
n2ma
    May 18, 2024
    May 18, 2024
