Budget System Questions
Please tell me that's not the built 350 you're talking about...
The one in the car? It was built 15 years ago, so the chrome has seen better days. New flat top pistons, new mains, new rod bearings, new cam bearings, double roller timing set, new oil pump, summit 3/4 race cam, edelbrock intake, holley 4160, gto heads, shave block .020, shave heads .010, stiffer valve springs, backed by a rebuilt TH350 with a shift kit. There aren't even 1,000 miles on the engine since the car has sat since 94". Just now finishing it up this fall.
i wouldn't use them but this was the quickest pic i could find if you are sticking with the fosgate amp 500 @ 2 ohm 320 @ 4 ohm why not get a fosgate sub that can take it here's a dual 2 that'll do what you want and give good output as a single ported sub
plus it'll match so you can do something nice as far as an amp rack goes and display your set up http://www.dealercostcaraudio.com/p2d210.aspx
alex211
Still learning
alex211
Pennsylvania
dappa5
vegang
vegang
