Sold Budget Equipment!!!
Witty690
Well, being an 18 year old working at Burger King, i could only afford a handful of budget equipment. Sadly enough, the only thing I used was the MJ-18, and frankly, I am sick of just looking at it. So up for sale it goes.
All prices include payapl, but not shipping
I will accept trades, depending on what it is, obviously.
First off, we have the MJ-18. Not the new MJ-18M, the old one. Had it for 8 months, but only used it for about 2 months in my Jetta. 5ft^3 @ 32 running off ~730 rms from a Power Acoustik PS2-1800 I believe. 9/10 cosmetically 9.5/10 mechanically. I dont even think its really fully broken in yet.
MJ-18 - 4 Ohms
Fs = 28 Hz
Re = 3.2 Ohms
Qes = 0.34
Qms = 4.99
Qts = 0.31
Mms = 229 grams
Rms = 8.1 kg/s
Cms = 0.14 mm/N
VAS = 208.4 litres
Sd = 1029.2 cm2
Xmax = 12 mm
Cone Diameter = 36.20 cm
Recommended Box Sizes:
Sealed: 80 litres (2.8 cu. ft.)
Ported: 128 litres (4.5 cu. ft.) 30Hz tuning
EBS: 250 litres (8.8 cu. ft.) 18Hz tuning
i know its a little dusty
and a shot of the magnet
Asking $110 shipped OBO
Next I have 2 MAW-15's, bought used from ctmike and ladi3sman55
Not sure how long they had them, but they both are still in pristine condition. Hopefully the can chime in. I wish I could wall these off in my 'stang, but moneys tight, and the car is starting to shit the bed on me.
MAW-15 - T/S Parameters
Power Handling: 500 Watts
SPL (2.83v/1m): 90.2 db
Impedence: 4 + 4 Ohm
T/S parameters (with coils wired in series):
Fs = 26 Hz
Re = 8 Ohms
Qt = 0.32
Qes = 0.35
Qms = 3.35
Mms = 232.8 grams
Rms = 11.42 kg/s
Cms = 0.000159 m/N
Vas = 129 liters
Sd= 756.3 cm2
Xmax = 13 mm
Diameter = 31.1 cm
Dimensions
Outside Diameter: 39.4cm (15 1/2")
Mounting Diameter: 35.6cm (14")
Depth: 16.8cm (6 5/8")
Magnet bottoms are still very clean, as you can see
Asking $95 shipped each, or $175 shipped for both
Next, I have a Cadence ZRS-8. It has a slight crack on the side, but with the handle on it is barely noticeable.
1 x 80W @ 4 ohms
1 x 750W @ 2 ohms
1 x 1500W @ 1 ohm
Freq. Response: 10Hz ∼ 500Hz
S/N Ratio: >100dB
Damping Factor: >500 @ 100Hz
Minimum THD:
Channel Separation: >70dB
Dimensions: 21" x 14" x 3" (53.3cm x 35.6cm x 7.6cm)
Crack with the handle off
Hmmm... no where did that crack go lol.
Asking $160 shipped. Thats ~ $.10 a watt!!
I got more stuff to put up in a little while, but I gotta run a couple errands.
Witty690
Witty690
Utica NY
bigbangtheory
