Budget Build - What you think?
jshak07
148.4 and climbing
Goin to do this for my buddy, in a Honda Passport. He is still in high school and just wants a decent street beater
(2) 12" Sundown SA-12 d4 $380
(1) Sundown SAZ1500 from dB-r $359
(1) Deka 9a31 with stock batt $150
(1) Positive Run 1/0 Welding Cable Red from Weldingsupply.com $42
(1) Negative Run 1/ 0 Welding Cable Black from Weldingsupply.com $49
Box around 4 cubes tuned to 36 hz
Thats around $930 not including fuses, terminals etc. Suggestions?
you think the aq2200 would be a better match?
I woulnt tune those aq's that low for one thing tune to 36-38 and you will still catch the lows.But I really would consider 2 sdc2.5 15's tuned at 35 it's gonna be louder than both 12's and a bit cheaper to do,he has the room.
yeah if you have the room, 2 sdc2.5 15's at 38hz not 35, on that saz1500 would hit harder than 2 hdc3 12's off 1500w, most people are running more than 1500w on each hdc3
or for that matter... and even cheaper, 1 hdc3 18 off that saz 1500 wouldn't be too bad
Id say research a bit more cause im sure you cand find a used btl or something very similar on here for cheaper than 359, as for amp, the ap30001d is like 300 new or if you get with basscort2009 he has an older ap that will do .35 burps his is good priced also. You also need to lookinto some components for that vehcle. Since when is budget build 1100, i think budget i think like 150-400 but either way GLWB
jshak07
148.4 and climbing
jshak07
louisville
misfit138
Mike Mccabe
