Buck's first TL score
don't feel bad my ext cab f150 with an hdc318 on 2200w probably didn't do much better. My composite 9515 on 3kw was definitely louder to the ear than my hdc318 setup
If anyone has an design in mind that would work better, tell me. Then I'll build it.
Buy some 6' inch aero ports, sub forward, ports to the side. Resin the corners. Wang away. Then i can be nice, and leave comments such as "wow, nice, good job, semi chubbie, etc"
another thought. When ever you feel like tuning higher etc for a burp, or where ever you may peak, just stuff a shirt or object to plug a port to instantly change your tuning. Easy as pie.
Bingo
Or port up....both should work muchhhh better
2 6in aeros , i bet you $20 bucks and will buy ur 6in aeros if it doesnt work, that youll do a 146-147 EASYYYYY with that design
Or even sub up port side....almost any combination would be better than what you got....set the bar a lil low //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I definitely don't know how to use/do resin.
I did a 143.6 with 2 12" SI BMs, not SPL subs at all, and in a daily box off of 1000 watts, Your score should be much higher.
What vehicle was it in?
Bingo
So 2 6 inch aeros. I really don't know how to design one. I could try winISD but it'd probably take me a month to figure it out.
It comes with instructions, or use this forum to learn. Let us know when your balls drop and your ready to get loud. Out for the evening, good luck. keep it simple. Box, aero ports, resin if you like, but its not even completely necessary. You will gain a considerable amount.
Thats the best part you dont need to do anything more than design a sealed box than throw in some aeros
Its not hard at all.
Find what size box you wanna do....id guess around 6-7cu(i never messed with 18s) and put 2 6in aeros in and BAM....LOUDNESS
Doesn't matter, you cant compare set ups.
You can't tell me that the vehicle doesn't matter. You can take two setups in two different vehicles and be louder in one than the other. Was it a stock vehicle?
Another note: truly, I have no idea really how much wattage the sub is seeing. The gain is set exactly half, and I have not tested it with a DMM yet.
Length of aeros?
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
