BTL Question
once again, the new crunch amps are solid.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
http://audioforum.termpro.com/topic/20/13407.html
I know they are solid, all I mainly run is maxxonics products. But 1500wrms is not enough power for a BTL. and 2 of them does not change it. These are not strappable. so getting one of these amps and a dual 2 ohm BTL is 1500w
getting 2 of these amp and a dual 1 ohm BTL is 1500. BTL=RMS 2000. It will power it yea but just not fully. I give mine about 2300 and its not all potential.
I wouldn't recommend running one 1500 to each voice coil. If the amps aren't strappable, then just sell the one you have now and upgrade to a single amp somewhere around 2500-3000W RMS @ 1 ohm and buy the Dual-2 version of the BTL.
If you run two amps, not strapped, to individual voice coils on the same sub, then each coil will be getting different signals. Sure you can split the input signal but it will be almost impossible to get the exact same amount of power running to each coil all the time.
sell the crunch and get around 2.5-3kw. What vehicle are you putting this in, you do not want to smother it in too small of a trunk. And what kind of electrical upgrades do you have? Need to know this to point you in the right direction for an amp. But if i were you I would not buy the sub until you have enough power to push it and make sure you have enough room for it and enough current to support the massive power these things take.
Honestly man, it seems like you're getting yourself way in over your head with this sub. You may want to look into something smaller like the BL which will require less space and power
jk123
jk123
Ohio
casper97ta
