bridging? any help appreciated
by bridgin you generally get more power from your amp, cuz you are sending 2 sin waves inverted i believe.
in you speaker connections in ur amp, in the bottom it may say if you can bridge it. usu it's + from one channel, n the - of the other channel. for 2 channel amp course.
check http://www.eatel.net/~amptech/elecdisc/caraudio.htm and go to amp bridging.
have fun
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
984
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
527
force fed
force fed
Perth WA
ftgu
