bigred78797
Audiobahn Junkie
Ok, i haven't been on here in a while and haven't done a Major install in a while so a little of my electronics knowlegde has left me so this may be a stupid question.
I remember way back when Squeak or someone( knowledgeable ) said that any any two amps of the same model could be bridged together provided VERY careful gain and SSF adjustment. I just wanted to know what would need to be done to two Audiobahn 8000T's to make them bridgable.
OK before the flaming starts YES it's audiobahn and YES i do love them, those 2 ohm stable bastards take 1ohm Like champs, I had 2 each hooked up to a Treo SSX 15.22 ( dual 2 ohm ). Now i have 4 amps and imma hook it up so it's roughly 1.6kw per sub. Big 3 done with 1 bat under the hood and 2 in the back. I want to know about the Bridging amps so IF POSSIBLE to get 3200w to each sub for tone burst. Ill be getting two more batts and another Alt (hopefully) so getting the power to them shouldn't be an issue.
Question #1: IS it possible to bridge any amp of the same make and model?
Question #2: If so, If i were to Wire one sub( dual 2 wired parallel (1 ohm) ) to a Pair of Bridged amps. What would the load on each amp be? .5 ohms?
Question #3: If i were to wire one sub( dual 2 wired series ( 4 ohms ) ) to a pair of Bridged amps would that be a 1 ohm load per amp?
Question #4: What would need to be done circuit wise to the amps to make them bridgable if not straight out the box.
Question #5: If it isn't possible at all you know where i could get 6Kw of power cheap?
Sorry some people refer to this as strapping the amps together and not bridging //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
