Bridging Amp?
Arkel23
Hey, I know you guys probably get this alot, but since it's probably hard to explain by typing, i want you to tell me which of these ways is the correct way to bridge one amp to a 2 channel amp or if both are correct.
(Jump to 5:30)or
How to Bridge an Amplifier | eHow.com And if I'm understanding correctly, ehow is saying put the wire in the very first terminal (A) and the very last (D), and then just put some wire connecting B & C?
Tried to watch that first vid for the hell of it, but stopped because dude needs to learn how to speak. Anyways most two channel amps will have markings on them indicating which terminals to use for a bridged setup. A line connecting one of the positive terminal with one negative. Use those. If it's not marked off, just use a positive from one channel and a negative from the other,
or read the manual.
Arkel23
Arkel23
Florence,SC
Arkel23
Mike Mccabe
