bridging amp - rca problem
doublevision
nj
I am trying to bridge my amp to power my component system and am having trouble with the rca cables. Do i use 2 pair of rca cables that connects from the front and rear outputs of my headunit to the front and rear inputs of my headunit? I read on this forum about people using splitters to bridge their amps. I wonder if i have to do this or not and how to do it. BTW i have a Diamond D3 400.4 amp.
coherrent question > your question
Hoping I am answering this correctly based on the info.
Bridging a 4 channel amp to a 2 channel amp only requires
1 set of RCA's to be run to the amp.
it was that hard to understand? so what do i do with the one set of rca cable? do i connect them from the front output of my headunit to the front input of my amp?
It does not matter which set you choose on the head unit, just
decide how you want your fader to work. On the amp, you have
to read the manual, cause I'm not sure, amps are different.
so on a kicker zx850.4 to run it on only 2 channels do i only need one set of rca's
one pair of RCA's that consists of a left and a right channel, usually
stuck together, yes. Thats all any two channel amp needs; even if
it used to be a 4 channel //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
doublevision
doublevision
nj
mcsoul
