Bridging a Jl 8w0
icemayne696
ngsm13-Douche Drinker
331
FL
Ok i am hookin up a jl 8w0 to a alpine flex2, here is the specs of the amp:Specifications
RMS Power (at 14.4V,20Hz-20kHz)
Per channel into 4 ohms- 40W x 2 (0.08% THD)
Per channel into 2 ohms- 60W x 2 (0.3% THD)
Bridged 4 ohms- 120W x 1 (0.3% THD)
The sub is a svc, 4 ohm. The amp has 2 sets of + and - . Im sure this is an easy answer, but i never really understood wiring all that well. Can someone tell me how to hook this up so i can get that bridged 4 ohms 120w x 1? Thanks a bunch //content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif
the + of one channel and the - of the other channel hooked up to the sub. That would give you the 120watts.
Well, usually amp speaker terminals look like + - + - OR - + - +, either way only correction i'd make is use the VERY outer two terminals...so the outside + and the outside -, that's bridged on most amps. BTW, you can't "bridge" a sub, you can bridge the amp... just keepin ya up on terminology. peace
NG
Just trying to make it simple for him like he asked.
icemayne696
icemayne696
FL
ngsm13
