bridging 2 mtx 12"s..
Its called bridging when you add power supplies together. On speakers, just say parallel or series. If the subs are 2 ohm you would end up with 1 ohm. If the subs are 4 ohm you would end up with 2 ohms.
Correct. but the amp is 2 channels.. I didn't know if I were to bridge the amp and run both of the 4 ohm speakers in parallel if the amp would "see" 1 ohm. figured since its sharing two channels using 1 speaker bridged would cause the speaker to go to 2 ohms? So if i were using 2 it would be 1 ohm.. I might be misinformed the reason why am asking.
The final impedance allowed on the amp to run bridged would have to be 2 ohms, if you run two, 4 ohm speakers in parallel. The amp doesnt change the impedance of the sub.
the amp will still have to side they are just being combined
Nope, two sides means 2 positives and 2 negatives, it does not have two sides when bridged. If it was wired up to have two sides you would be unbridging it. When bridged, amps channels are, to put it simple, series wired to get 1 large channel.
im talking internal not external if his amp says 100x2 at 4 ohm,,200x2 at 2ohm,,then it should be 400 at 4 ohm mono,,which would be the bridged channle seeing half the ohm load wired to it right
vandiar2
vandiar2
monroe, la
oldschool4me
