bridged mode?
if you are talking a 2 channel amp bridged, then depends on the amp. ihave seen some amps burn up 2 ohm bridged that is supposed to be only 4 ohm stable, and then some get hot and cut off. when cooled down come back on. it depends on the amp
hey actually i was thinkig i used to have a autotek sx-2300 that was stable at 2 ohm bridged. maybe if you could find one like that it would work. i don't know how much power you need.
well my mom already has an amp, mine is on the way and just wanted to see how it sounded. it says its only 4 ohm stable bridged but my sub is hooked up for 2 ohm. i just hooked it up and about 10 minutes of play the amp got real hot. so before i messed it up i just shut it off. so im pretty sure everything is alright.
I've run a Rockford P2002 bridged at 2 ohms for 2 years now. It gets hot and shuts off once in a blue moon, but its a trooper.
It all depends on the amp, and whether or not you like Russian Roulette.
I prefer Polish roulette ....... it's basically the same as Russian ruolette, only you use an automatic instead of a revolver //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
chrisw91
chrisw91
phoenix, az
helotaxi
