Bridge an Amplifier
  • 4
cozmikx
Hiya,
I'm retarded and I was wondering how to bridge my amp. I did a search and all I got was confused. See, I had my amp and subwoofer installed professionally, but they didn't bridge it. So, I was wondering how to do it, I have a 400 watt 4 channel amp (right now it's on 2 channel, but I'm only powering 1 subwoofer), so I just want to bridge it over so I can get full power out of it.
Thanks for any help that you could offer me!
problem is that some amps are not bridgable.....if i were you i'd look at your user guide...it should tell you if u can do it or not.....what type of sub do u have and what is it stable at in sterio....if its mono stable let us know what its stable at and if ur sub is dvc/svc and what its rated at ohm wise
if you have a 4 channel amp, and you bridge it, you take the power from 2 of the outputs and hook it up to one sub, and take the negative of the same outputs, and hook them up to the subs. therefore, if you have a 4 channel amp, you can bridge it down to 2 channels, i'm pretty sure you can't bridge it twice. sorry:(
Yes, Moocow,.....EVERY day.
Goddy is right, this would be a lot easier with more info. (amp stability and power and if the sub is DVC or SVC [i assume that it would be a DVC since they bridged a 4 channel to it...right?] what ohm amd power handling.)
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
cozmikx
cozmikx
Navarre, FL
Trixter
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
