bp box for 2 L7 12's what do u think
tgclark84
First off this will be my first bp box, I 've done my sharre of sealed and ported but I thought what the heck Ill give this a try. Equip is 2 L712's and they will be ran by 2 brutus 2608d's. The vehicle is a 89' s-10 truck. The box will be in the bed with a blow through under the window line. The truck is bagged so I have room only to the knotch cover. 55x15x25 is what I have to work with. This is just going to be a daily box but on occasion it may go to a comp.
Heres what I was thinking of tring.
Sealed 1.25cuft per sub
ported 6.0cuft with 120sqin of port to 50hz
The subs would be on opposite sides of the bed firing at each other.
So what do you guys think? Any input is very much appreciated.
do 2.5^ft3 sealed rear and 3.5^ft3 front with 90square inch ported area tuned to 56hz
80
Since I cant put the subs in the same sealed part of the enclosure they will have to be in seperate sealed enclosures. Should I do them both in 2.5^ft3 each or split what you said and do each in 1.25^ft3 firing into the 3.5^ft3 at each other?
tgclark84
tgclark84
charlotte, nc
tgclark84
