Box???
SEVEN_ELEVEN
Ok so from what you guys have told me in the last few days I have decided on 3 10" 2 ohm Kicker Comp VR's and a Power Acoustik 2100w mono block amp. Since these will be going behind my seat the box will not be able to be very big. Because of this should I make it sealed instead of ported??? I measured all the demensions behind my seat and this is what I came up with:
http://s99.photobucket.com/albums/l307/rpetty429/?action=view&current=310s.jpg&refPage=&imgAnch=imgAnch1
I think its gonna end up bein about 2.5 cu ft. Is this big enough to port. Or are these subs louder in a sealed box????
Any input would be greatly appreciated. Thanks
The generally quoted number is a pound per square foot...but that's a pretty flexible number, add or take away to get the desired sound //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
IMO, makes it fuller. A lot of people may argue that. I would definitely put poly in there. Is the box 1.5ft^3, or 2.5ft^3? If 1.5, honestly, you will prob get louder with just 2. Those CVR's need a little room to come alive. I have 2 CVR 12's in a cube a piece, and they really act like they need more. I would go 2 CVR's with aero ports. That should get louder than the 3 sealed. Even if it was all one chamber, that small of a box I have to think atleast one sub will become passive.
What type of truck is this going in? Your box is very shallow on top, and deep in the bottom. That is not going to help seat space any. I would proportion that out a little more, maybe 5" on top, and 11 bottom depth. That would probably get you a little more seat room. Is 47" as long as you can get?
SEVEN_ELEVEN
SEVEN_ELEVEN
Leavenworth, KS
SEVEN_ELEVEN
