box tuning
  • 6
from what I know of, speaker will easily play below FS but will peak closer to FS freq than tuning. here's and example SA-8s have a FS of 41 but are suppose to be able to play down to 30hz.
Fs Driver free air resonance, in Hz. This is the point at which driver impedance is maximum. "This parameter is the free-air resonant frequency of a speaker. Simply stated, it is the point at which the weight of the moving parts of the speaker becomes balanced with the force of the speaker suspension when in motion. If you've ever seen a piece of string start humming uncontrollably in the wind, you have seen the effect of reaching a resonant frequency. It is important to know this information so that you can prevent your enclosure from 'ringing'. With a loudspeaker, the mass of the moving parts, and the stiffness of the suspension (surround and spider) are the key elements that affect the resonant frequency. As a general rule of thumb, a lower Fs indicates a woofer that would be better for low-frequency reproduction than a woofer with a higher Fs. This is not always the case though, because other parameters affect the ultimate performance as well."
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
Gents I appreciate your knowledge and you sharing it. This is helpful in my understanding.
440
macsdad
boom-boom
macsdad
Trussville, Al
RangerDangerV2
    May 31, 2024
    May 24, 2024
