box to amp questions
dnb
I have a question about wiring my subs in my box and then connecting the speaker wires to the amp.
Okay so I have a two chamber box which is split down the middle. Both chambers are air tight of course, but i was wondering if i could wire both of them seperate in their own chamber and then where i am suppose to connect the wirings from the outside of box to make the load to a 1ohm to the amp. So each sub would be wired seperately and then when they are inside in their chambers i would put the positive and the positive and the negative and the negative from each sub and then connect them into the amp and would that give me a 1ohm load?
I have two Kicker 12" cvx dual voice coil 4ohm subs.
http://www.cardomain.com/item/KIC06CVX124
and a Kicker SX1250.1
http://www.cardomain.com/item/KIC04SX12501
dnb
dnb
Stuart, Fl
mile098
vegang
vegang
