box specs??
ok, after doin some research: dv is the recommended port diameter in mm right? I converted 65mm to inches and got 2.55905, isn't this a little small for a sub? Does this mean I could use (2) 4" aeros (~24 sq. inches)???? Thanks in advance
What the hell is your first post asking?
Two 4" diameter ports for a single 8" sub is way overkill and your port length would need to be huge!
What should do is what they emailed you. Roughly .6 cubic feet before port and sub displacement and then a 2.5" port about 21" long. That should be a great enclosure for that sub. Why do you keep bumping this?
Nobody was replying because you didn't ask anything in your first post. You posted specs to an enclosure that will work well with your sub and it was recommended by the company... what more did you need?
If you're going to do 4, two 4" ports should be alright. They would each need to be about 26" long.
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
