box sounds like chit
sinosic
Idyllic Enclosures
i few weeks i hooked a friend of mine up with a trade were he ended up getting a new re mx 12" sub. i made a box (moe's lesters) that was i think 2.25 cubic feet and tuned to 33hz, the sub in this box sounds slappy muddy basicly like chit. he is underpowering it a bit with a pheonix gold 1200.1 ( i think ). the sub is wired in series to show a 4ohm load i beleave. why would this setup sound so bad? its all installed in xtra cab truck. i thought it would pound. any ideas?
leak in the box?
maybe, but i sealed all the joints on the inside pretty well. there is a alot of port noise. 33.something port area, it shouldnt sound that bad, do you think thats enough. would the way the sub is wired to the amp (+ to - and - to +) matter? cause we mounted the sub and forgot which wire was possitive and which was negitive.
his amp is Phoenix Gold Tantrum 1200.1 specs:
Amplifier Type: Mono
RMS Power: 1200W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power: 1400W x 1 @ 2 Ohms
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >95 dB
Fuse Rating: 80 amps
why is this setup sounding like a moose farting
sinosic
Idyllic Enclosures
sinosic
roseville,ca
dyabolical
