Box Question
walkychalky
Currently I have two 12's but am upgrading to two 15" RE SX's.....they will be powered by an orion 2500d.... here is a quick sketch of the box i am using now: http://img357.imageshack.us/img357/9914/enclosure7zy.jpg
It's made with 3/4" MDF
so my question is do u think that this box will be a nice match for my new subs if i cut the holes larger so that they fit 15's? or would u suggest a whole new box?....i would like to keep this one because it fits perfectly in my Grand Cherokee and looks very nice....but i dont want my new subs to sound like **** in it....so any suggestions?....i dont know anthing about building boxes so i would have to pay for someone to build a new one.....so lemme know what your guys opinions are. Also, if anyone could let me know what the box is tuned to n its volume that'd be very helpful....i forgot what it was n dont know how to figure it out. (The calculators only confuse me)
Thanx
Looks good, RE recommends 3.5 per 15 SX for SQL, and you're giving them a little under 7.8( i dunno what ur subs displacement is, closer to 7 after displacement) for both with a tuning at about 31. pre-displacement of subs.
Wrong.
very informative
//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif
Its either 7.8 @31 or 6.3@34 depending on how u measured it.
Box = 6.73 before any displacments. Granted those are external dimmensions.
Port displacment = 0.56
Speaker displacment will be 0.36
So 5.81ft^3 after displacment. That's only 2.91ft^3 each and you will need a bigger box...
so if i wanted 3.5 cubes per sub after port and sub displacement.....tuned to about 32 Hz...... what would the LxWxH (external) have to be?....would it fit in a space thats 45x21x19?.....
could u give me the dimensions it would take.....maybe extending the length and width a lil bit....i could maybe gain an inch or two either way....or would this still not be enough?
Actually those dimmensions wrok out pretty good.
Box - 45" x 21" x 19" = 8.59
Slot Port - 17.5" x 4" x 16" = tunned to 32hz(31.83)
Each speaker will have 3.73ft^3
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
I played with the current setup I have and it's a sub port same side box. Seemed cleaner up but hit way harder faced back. I didn't know how much...
walkychalky
walkychalky
San Jose, CA
walkychalky
