Box mounting depth question
DjDan101
On a box for my truck that I'm looking at, it says the mounting depth for a 10 is 6.5 inches. A sub that I found that I want is the same number, and the airspace almost matches up. Does that mean that there is only 6.5 inches of clearance from the hole in the box to the bottom of it, or that is the most that should be mounted in it and it still be optimal? Here is a link to the box just in case you need to see it https://www.soundoffaudio.com/item.cfm/id/732
DjDan101
DjDan101
Lawton, OK
DjDan101
