Box Modification SPL Gains
sundownz
Pro Seller
Supporting Vendor
I am going to start putting corner pieces in my box as well as adding resin. I will be tracking my gains from these things here.
I will do each corner with a 45 degree piece first (ripped 4x4 lumber). I will also try pieces that are cut into an arc (same 4x4 but with an arc cut) to see which is louder.
This will be done one corner at a time.
This may take a while but I am going to start today.
Base-Line score from the end of my dampener log :
155.2 dB @ 48 Hz
First piece in place - screwed in with tape along the top as that edge was rough:
This resulted in a GAIN :
I tested 49 Hz as well to make sure my frequency did not change - I metered 155.2 dB @ 49 Hz. I also gained 0.1 dB here compared to before but it is still not as loud as 48 Hz.
While I'm in the area I tried something random - metal taping all around the plastic trim piece at the bottom. I didn't have enough time remaining today to take the whole box out and do another 45 piece so I wanted to try something //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No change... but at least my 155.3 is consistant :
There was alot of odd noise on the meter this time, though... not sure why, maybe a fluke.
good to know some foil tape isnt going to help my car...
I've gained 0.1 in a vehicle doing 158s with a single piece of foil tape before //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif So it is always worth a shot!
I first looked at the pic of the TL readout WOW Your woofer hit's every note //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Then i read your last line:laugh:
By box mods are you agjusting the port length too. When your competing having that "it's not gonna make me louder" mentality will do just that. Keep making those gains for everyone to see.
Drew
I wanted to see how much my internal port PVC piece was doing so I took it out this morning :
* With
* Without
Without - 154.9 dB (verified two runs 12 minutes apart)
With - 155.2 dB
So that piece is worth around 0.3 dB!
The score "with" is within tolerance since my speaker wires moved around in the port with the subs in and out... I need to get those out of the port - will probably do that today before further testing to eliminate that variable.
I'm ready to see the resin put in, I got about 3 gallons in mine and I could tell a difference when I did it, but didn't meter before or after.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
xfl
BP1Fanatic
BP1Fanatic
