Box Material
Gunny,
I wouldnt suggest using it if you want any kind of actual sound quality out of it. You should be able to come up with a whole hell of alot more then that if you run through your S-4 and give them the correct NSN. A sheet of MDF (medium Fiber Density Board) is the most commonly used material for a few reasons.
1) it is best for dampening resonant frequencies and absorbing vibrations within your enclosure
2) it is generally a whole lot easier to work with. (no chips or splinters coming off your pieces. you could tape up the cut lines on the ply wood, but the finished piece is still rougher)
(you know now that I think of it... I wonder if your S-4 could order some MDF for you??? just kiddin.
MarineGYSGT
MarineGYSGT
Ft Worth, TX
joeldirt
