04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 #1 i fail at box building, and give up on car audio. Click to read more...
jellyfish420 10+ year member i design boxes ....... 4,234 0 STL ill side Jul 15, 2007 #3 is that port diff width throughout the box? thats an awful long narrow port...
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #4 its three inches wide at the outlet, (you cant tell because of the carpet though) and is something like 4-4.5 on the backside. its not port area thats the problem. i canabalized my old box, and it never made this noise before.
mobeious 10+ year member what does 0hz feel like? 4,963 5 Bartow, FL Jul 15, 2007 #5 ummm ok the port is different sizes??? goes from 4 -3"
jellyfish420 10+ year member i design boxes ....... 4,234 0 STL ill side Jul 15, 2007 #6 just cause your old box sucked, doesn't mean this one cant. 4.5 down to 3 at the outlet??? and yeah you should have your port closest to square/round as possible to prevent laminant air flow...
Chevyaudio 5,000+ posts :poof: 13,818 157 Back in the Dirty BR, Louisiana Jul 15, 2007 #7 changing port area isnt good...no telling what its tuned to.
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #8 well when i did the sketchup in winisd those are the dimensions it gave me... its supposed to be 4.5^3 ft 54^2 inches of port, tuned to 34 hz
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #9 actually the back 3 or 3.75 inches wide, im nor sure..... edit: just measured and its 3.5 inches on the back side.
jellyfish420 10+ year member i design boxes ....... 4,234 0 STL ill side Jul 15, 2007 #10 so how tall is the box?
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #11 22.5 ........................
Chevyaudio 5,000+ posts :poof: 13,818 157 Back in the Dirty BR, Louisiana Jul 15, 2007 #12 Is there any reason why you didn't make the port a uniform length through-out the enclosure? It would be great if you can post up the plans, or a schematic of the box...that way a few of us could look it over.
Chevyaudio 5,000+ posts :poof: 13,818 157 Back in the Dirty BR, Louisiana Jul 15, 2007 #13 33.5 in Click to expand... well...if that 33.5 is external that means 32" x 3" port Giving you 96 square inches of port...not 54.
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #14 jesus ****ing christ. ok again im half asleep. its not 33...whatever tall its 22.5
OP 04_edge 10+ year member iPhail. 2,960 0 Rowlett, TX Jul 15, 2007 Thread Starter #15 the dimensions are front: 22.5x32.75 back: 36.5x 24 top: 36.5x 12 bottom: 36.5x 12 sides: 22.5x12 port length 1:7x22.5 port lenght 2: 22.5x21
