I came up with 14"deep, 14"high, and 35" wide and that came to 3.029^3ft. Would that be ok. Also can someone come up with the size of my port i am doing a slot port and would like to stay at 32hz because that is what my box is now.
I'm working with a guy on here to build a box for two SE12's. his dimensions are 29x29x16... that is for a honda CRX... each chamber is 3.08 befor displacement. After internal bracin g, port displacement, sna sub displacement, we will have 2.5 tuned to 35hz ea. THat box is for two SE's, but I am sure it will suit your RE's just fine as well. YOu can tune it to anything you want. That box may be too bigf for your car thoughyea that totally makes since. Does anyone have a plan that i could use for a box or know where i can get one? it would be very helpful. thank you very much.
Max Dimensions are 17"H x 35"W x 19"D' date=' i like the way mine is tuned to 32hz so probably keep this one there to. I have access to all tools pretty much. And i am just going to keep the wood look.[/quote']
okay good dimensions for your sub. now do you want round or slot ports?
When using sealed it's generally worth the time to have separate chambers, but ported it is very common to do a common chamber. It does not affect sound, and is easier to design, along with using a ton less space.It's not a crime to build a box with a single chamber for two subs. But it is prefered when aplicable to have an individual chamber per sub because first of all, it provides internal bracing to reduce vibration and panel flexing.... Each subwoofer should have its own chamber any way since its kind of like a circuit protection measure.
I dont use the recommended box volume suggested by the manufactures. I use a larger box due to efficiency. I dont use the recommended port size either, i use a bigger port. I dont use internal dividers, i brace it with 1" wooden dowels. I give my enclosure a slot loaded port and that also helps with bracing. I dont think, well I know it wouldnt get better spl. Have tried both types of boxes and having 2 subs in the same chamber produces more spl because they share the same port. Puts a lot of pressure to the one port. Not dissen what you said but id agree to disagree. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifHowever they would actually sound alot better, given the subs are built to their own seperate chamber. (you can still do this while giving the same exact shape as the box without the internal deviders. Takes more time, but produces better cleaner sound quality, frequency response, and over all SPL since you have a much more sturdy box with the subs playing in exactly their intended box volume........
how can you post a link from your own personal experiences in differences of the two?link?
