Box for ZVX-8, need some input.
The_Dealer
I won a new skar zvx-8 over the weekend and I'm having a hard time deciding on box size and port area. I did a few designs and and this is what I came up with
Anyone have any input? I'm concerned whether I'll have enough port area, and wanted to see what you guys think.
Sent from my G870a on 38's
Never done one before, so I wouldn't know where to begin. Feeling generous enough to design me one? I haven't won anything worth a **** before, so I'm kinda anxious to get a box built.
Port per is really high at 19. You'll lose bandwidth. Get it down to 14-16". What's the fs of that sub? That along with the SD (piston diameter) would help in designing a tline. Get me those and I'll help you out.
I can't find the sd, but here's what the manual has. Vas: 5.18, fs: 45.3, bl: 18.9, qms: 3.93, qts: .42, qes: .49, n-%: 0.080%.
---------- Post added at 12:55 PM ---------- Previous post was at 12:54 PM ----------
How did you win this sub?
Local raffle
I can't find the sd, but here's what the manual has. Vas: 5.18, fs: 45.3, bl: 18.9, qms: 3.93, qts: .42, qes: 8.49, n-%: 0.080%.
Local raffle
Just measure the center (highest point) of the surround from one side to the other. That's your sd. Should be around 6.5-6.75".
It's right at 6.25". I don't know much about T-line boxes other than they are a lot bigger than a normal ported box. I'd like to keep it under 28-30" wide if possible, but my max dimensions are 40" width and 19.25" depth, height isn't really an issue. I usually tune to 32hz, but not sure if it would be the same with a T-line
tune to the projected FS of the sub after its broken in. So if the FS of the sub is 35hz you can go down to 32 or so depending on how much the suspension could loosen up as long as its a little bit below FS you should be fine. If you have a machine that can pull direct TS specs, you can make a very technical box that is tuned exactly at the FS of the broken in sub and get the best bandwidth.
Quoted from brandon buck on the facebook T-line basshead forum https://www.facebook.com/groups/990108914350137/permalink/999150813445947/
"DESIGNING YOUR T-LINE
This will be a quick and simple primer on how to design a consistent dimension ¼ wave t-line. There are a variety of different ways to build t-lines but this will be an explanation of what has been, for me, the easiest method. For the example, we'll use a single, hypothetical 15' driver.
First thing we need from our sub is Sd or, usable piston area. To find that we need the diameter of the driver, which is measured from the apex (center) of the surround on one side of the driver to the same point on the opposite side. For most car audio 15s, that measurement is 12.75".
Then we take that measurement and half it: 12.75 ÷ 2 = 6.375
Now apply the formula πR² to that number: 3.14 * 6.375 - 6.375 = 127.6
For our purpose, that number can simply be rounded to 127in².
Sd will be out line area. Line area is what would be called port area in a conventional vented enclosure but since our box is nothing but one long port or, line... it's called line area. This number can be modified for a couple of different reasons. First off, if your design is strictly for sound quality, I'd leave the line area equal to Sd but if you need to save space or you want a bit more of an SPL oriented box you can reduce that number by up to 40% with no serious affects on sound quality. What you will lose, in my experience, is performance on the top end of the sub bass region (60-100Hz). But, that loss is minimal, especially in a vehicle cabin. Aside from the aforementioned benefits, reducing line area also seems to increase cone control, which is really important for us bassheads since we tend to abuse our subs on a daily basis. smile emoticon
Next we have to calculate the tuning frequency of the line. For that you need to know the speed of sound in feet. That varies with elevation and other factors but for my area and conditions it's usually 1130 feet per second so, that's what we'll use. You can find it for your area if you like but for the purposes of what we're doing there is no need of that much accuracy. We'll tune our line at 30Hz, which is the most common tuning I use for daily builds. The formula is speed of sound ÷ tuning ÷ 4. This formula tells us the length of a sound wave at the tuning frequency we chose and then we take ¼ of that length for out box... hence ¼ wave transmission line.
For our box: 1130 ÷ 30 ÷ 4 = 9.41'
To convert that to inches: 9.41 * 12 = 112.92 or, round it to 113".
Now that the easy part is over we have to figure out a way to contort our 9' long square tube around and into the trunk or back seat of a vehicle. That's where line area reductions become pretty handy because even though the line won't get any shorter, its bulk will be lessened. If you have a large footprint but not a lot of height, I would recommend a snail shell styled box with the sub(s) in the center facing upward and the line terminus (port) facing out the side or rear, as in a trunk. If you have a wide but narrow space for the box, like the back seat of a truck or behind the back seat of a truck, a folded design with sub and terminus up works pretty good. Either way you're going to have some 90° and/or 180° turns to make and below I'll explain how I calculate the length of those turns.
The formula for circumference is πD or 3.14 * diameter.
For our box we'll assume the line dimension is 14" wide by 9" tall. I arrive at that measurement by dividing our needed line area (127in²) by the mounting diameter of our typical 15" driver (14") for a height of 9". Knowing that the line is 9" tall is important because that's the number we'll use to measure the length of our bends. Next we'll ad the thickness of our construction material to that number, which is normally 3/4" so... 9.75 is the diameter of our radius bends.
Now apply the formula to find the length of any 90° or 180° bends....
9.75 * 3.14 = 30.615 or rounded to 30.6. That's the circumference of our radius.
For 180° bends, divide that by 2 for: 15.3".
For 90° bends divide by 4 for: 7.65"
So now all you have to do is draw the line out and enter those numbers into any bends you have and then add them all up (along with the straight lines) to get the total length of your line. For a simple box I normally take my two most critical measurements and then start arranging my lines and bends through the center point of the line height until I find an arrangement that'll work.
Lastly, when figuring wave guides (45°s) for the bends, just measure from the pivot point of the radius at a 45° angle out to the desired line height and then measure across the line 90° perpendicular to get the width of your wave guide."
I've actually been thinking of getting the Dayton t/s setup from parts express so I can get exact t/s parameters. I've been building a fair amount of boxes locally, but have been limited to slot ports. I've been experimenting with aero ports on my personal stuff, but have been wanting to try a T-line out. Hopefully cscstang can hook me up. I just picked up a new router table today and can't wait to start on something
It's right at 6.25". I don't know much about T-line boxes other than they are a lot bigger than a normal ported I'd like to keep it under 28-30" wide if possible, but my max dimensions are 40" width and 19.25" depth, height isn't really an issue. I usually tune to 32hz, but not sure if it would be the same with a T-line
You'll have much more bandwidth than a ported enclosure. They will actually play an octave below tuning as well. I'm going to take your measurements and draw something up at 32hz. Looking at your dimensions I believe you have plenty of room for a single 8" driver.
The_Dealer
The_Dealer
Macon Ga
The_Dealer
