Box for two HDS215s
dev199505
US
Gonna build a box for 2 HDS 215s trying to decide between 6^ in case I upgrade to more power or do recommended and build it at 7^. Gonna tune it at 40hz I think that should be a good blend between music and competition correct?
Sent from my 5054N using Tapatalk
go 7.5 - 8 cubic feet tuned to 38hz unless you plan on putting a 3k to them.
6 is too small bud. 7.5 minimum.
how does this look and how would I factor in common walls and port bracing? Was also thinking maybe a removable port?
Dude I think you've got the measurements mixed around, your port is 44.5" wide port? Either way, that's not near enough port area, I'd at go to around 15.5sqin per cube
Sent from my Motorola 2950 Special Edition 3w
dev199505
dev199505
US
dev199505
vegang
vegang
