Box for Treo 12
Treo recomends 31. My Treo 15 was at 30 and I loved it..Id like to be slightly higher for competing sake. Perhaps closer to 34-35
and yes, low tuning>god
Well what they give you is tuned right around 35hz...box is kinda small though. If you can feed it plenty of power, no problem. But if you're hangin around RMS or a little less I'd go for something bigger, like 2ft^3.
Eventually it will get more power, but right now its only going to get slightly over rms.
And I know it probley seems small, but Treo always reccomends small enclosures. My 15 was in 2.5cu ft@30 and it slammed very hard
although it should be noted that the 15 was getting 500 over its rms
might have liked it better in a little bigger box.
I had a box that was about 3.25 or so, but tuned up around 38 and it sounded like shit. I think that enclosure was too big for it to be getting fed well over rms on a daily basis. I set the subsonic like at 30-32 and it still sounded like it was bottoming out
The 38hz box was just not very good at all. Despite it being tuned that high, I would not have been surprised if the 30hz box metered higher then the 38. The 30hz box was designed by Supergumby and he did a good job. The 38hz box was a crap job by a local shop (No i didnt buy it..lol)
winISD works great
I downloaded it, but couldnt figure out how to input my driver because it wasnt on the list...I actually ended up trying the RE calculater and that one is very simple to use. I was actually pretty close, when I input the dimensions and port width and length it came out to 34.5---- Hz, close enough. It was also like 1.63cu ft, again, close enough
kr15
Polluting Residentials
kr15
California
kr15
